Boost gauge discreetly installed. (Post your custom pics if you want)
Old 09-08-2007, 08:37 AM
  #41
Moderately Differentiated
dewmanshu's Avatar
Originally Posted by shakinlm7
Hey Dewman, what is that installed above your passenger airbag switch?
It WAS a laser detector/blocker, made by Bell. But sucked ***, I have since remvoed it also. I have Blinders on now, which is just a switch and that's next to the passenger airbag under that Bell laser controller.
kb, I really have always liked that. You guys find doing that modification that hard?
Old 09-08-2007, 10:06 AM
  #42
5 year bitches!
Quik's Avatar
Originally Posted by kbracing96
Here's mine
i likethat, is that a 2 1/16th or is that a 2" also how much work was thta with cutting the backout? anything had to be relocated?
Old 09-08-2007, 10:20 AM
  #43
shakinlm7's Avatar
How well does the blinders work? I had a rocky mountain radar detector/scrambler and it wasn't worth a crap!!! I need one that works! Or I could just stop speeding
Old 09-08-2007, 11:15 AM
  #44
kbracing96's Avatar
Originally Posted by Quick
i like that, is that a 2 1/16th or is that a 2" also how much work was that with cutting the backout? anything had to be relocated?
It's not that hard, its a standard 2 1/16" gauge. The cluster just unsnaps and I used a 2" hole saw to drill though the face plate and then drilled a hole though the circuit board for the light and vacuum line. There is the provisions for the tranny temp gauge on the circuit board, but it doesn't hurt anything to cut though them. I used my die grinder to finish fit the gauge and then to enlarge the stock bezel to fit around the gauge bezel. If you can remove the glass from the boost gauge without hurting it, I would recommend that, as I get a bit of glare from it in some conditions
Old 09-08-2007, 11:22 AM
  #45
5 year bitches!
Quik's Avatar
i see your broke the line on that one hole...was that for the trans gauge?
Old 09-08-2007, 11:25 AM
  #46
kbracing96's Avatar
Ya, doesn't hurt anything since its not used in this style of cluster.
Old 09-08-2007, 11:48 AM
  #47
5 year bitches!
Quik's Avatar
ok thanks for sharing, might just have to do that
chopperloco
07-10-2016 10:45 PM
thunder550
10-08-2015 04:53 PM
chacho44
08-17-2015 03:36 AM
carid
07-24-2015 05:00 AM
Quick Reply: Boost gauge discreetly installed. (Post your custom pics if you want)
