Boost controllers Owners?
Old Nov 5, 2014 | 07:10 PM
Atomic's Avatar
I have a gauge for that
Originally Posted by TrickPerformanceProducts
In this mode then why need a controller?
To actively keep the gate shut below my target boost to improve spool time and have more control over the target boost from inside and without messing with springs. I run about 25psi on 6lb springs and can adjust anywhere in between with the controller.
Old Nov 5, 2014 | 08:31 PM
Byrdman11's Avatar
I use the AMS 500. I use the first stage the control launch boost and when the truck get about half way threw first gear I stage ramping up the boost.
Old Nov 5, 2014 | 08:44 PM
LPCWS6's Avatar
eboost2 I just use mine to control from what speed I want to burn rubber from. lol
Old Nov 5, 2014 | 09:14 PM
oakley6575's Avatar
I use the AEM trueboost and love it. Super easy to use. Has the gate pressure, A, and B settings. It also lets you control crack pressure. So I have mine set up so it keeps the gate closed until my desired boost level is reached. Just like richard said, it is a tremendous aid in spool time. Makes running a bigger turbo no issue on a smaller engine.
Old Nov 5, 2014 | 09:26 PM
Ferocity02's Avatar
eBoost street. I have a low setting which is as low of boost as possible, usually ends up being 3.5-4psi. Then a high setting which is about 12-14psi. It also turns on power to my methanol controller.
Old Nov 6, 2014 | 07:03 AM
Atomic's Avatar
Oh yea I have mine turning on my second fuel pump at 1psi as well. Forgot about that.
Old Nov 6, 2014 | 08:26 AM
slowec's Avatar
Eboost2 here. Six settings , spring, 7,9,11,13, and 14 psi. I have it set to cruise around on the first setting that is pretty much the spring pressure. if I want to play, I hit a momentary which activates the timer setting and once I have traction the wot switch starts the timer to ramp through all the settings. It works well so I can run street tires and not do unintentional burnouts.
GXPJAY
Feb 13, 2022 08:15 AM
greedygenius
Sep 3, 2015 06:51 AM
Razor
Aug 16, 2015 11:39 PM
lxcoupe
Jul 15, 2015 10:03 PM
