Boost controllers Owners?
To actively keep the gate shut below my target boost to improve spool time and have more control over the target boost from inside and without messing with springs. I run about 25psi on 6lb springs and can adjust anywhere in between with the controller.
I use the AEM trueboost and love it. Super easy to use. Has the gate pressure, A, and B settings. It also lets you control crack pressure. So I have mine set up so it keeps the gate closed until my desired boost level is reached. Just like richard said, it is a tremendous aid in spool time. Makes running a bigger turbo no issue on a smaller engine.
eBoost street. I have a low setting which is as low of boost as possible, usually ends up being 3.5-4psi. Then a high setting which is about 12-14psi. It also turns on power to my methanol controller.
Eboost2 here. Six settings , spring, 7,9,11,13, and 14 psi. I have it set to cruise around on the first setting that is pretty much the spring pressure. if I want to play, I hit a momentary which activates the timer setting and once I have traction the wot switch starts the timer to ramp through all the settings. It works well so I can run street tires and not do unintentional burnouts.
GXPJAY
Feb 13, 2022 08:15 AM
lxcoupe
Jul 15, 2015 10:03 PM
