Boost between altitudes
Old Mar 7, 2006 | 07:04 PM
hemifever's Avatar
Default Boost between altitudes
I have a friend at 6000' elevation that runs 12psi of boost on their stock internal hemi ram (STS kit). I am at about 200 ft elevation and run 8psi. How can I compare what boost we equal out to? I mean, if I run 12psi on my stock bottom end I'll bend a rod into a pretzel I'd imagine.
Old Mar 7, 2006 | 11:01 PM
kbracing96's Avatar
6000 ft will be aprx. 20 kPa less then sea level (100 kpa). So he will have to make almost 3 lbs of boost more to be moving the same amount of air. (6.9 kPa=1 lbs of boost)
I went from from 4800 feet in WY to 1200 feet AZ and gained 11-12 kPa at the same 7 lbs of boost in the scanner.
You probably won't bend a rod, but you might brake a ring-land on a piston from detonation if your tune is not correct.
Old Mar 8, 2006 | 01:27 PM
vanillagorilla's Avatar
I saw 11psi on the dyno this weekend. That's 1psi more that I make here. Its about a 2500ft difference in DA.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
