Boost bet with MAF or SD?
Technically you could just disable the MAF and have a 1 bar SD tune... Really no point in that though, as most who change to SD run forced induction of some sort and upgrade the operating system to support higher capacity MAP sensors.
so if i were to be running a higher Hp and quite a bit of boost i'd wanna go with a 2 bar or even a 3 bar SD tune? and same with map sensor obviously. are there any huge benefits to running SD tunes that you see Smokeshow?
With the older trucks it is beneficial because you run out of MAF. You need a 2 bar MAP sensor for a 2 bar tune. As for benefits, there are good and bad things. Depends on who you talk to, and honestly whoever ends up tuning it.
