BlownChevy: Need help pls!!!
Old Feb 6, 2006 | 12:53 PM
dhpro's Avatar
Mech says he didn't check for that, but plenty labor $ to do it, as the only way to tell is to pull it. Wudn't it make some noise at least if it was slipping? If it was slipping enuf to lose 4 psi, it must be having some effect on the balancer, no? Whats in the way that makes it so hard to get to? R/
Old Feb 6, 2006 | 01:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Not hard to get too there.
What do you have done to the exhaust other than the long tubes? The long tubes and a free flowing exhaust would drop boost a bit too.
Old Feb 6, 2006 | 01:17 PM
dhpro's Avatar
LT's with high flow cats, Magnaflow Cat back....but its been this way since day #1 as they were all installed at once and spec'ed with Mag before we installed it. R/
Old Feb 6, 2006 | 01:21 PM
vanillagorilla's Avatar
Not necessarily. Its probably slipping when you hit the gas, which is when the blower, engine, exhauast etc. is the loudest. It doesn't take that long to do at all. It takes longer to pull the fan and shroud off.
Old Feb 6, 2006 | 01:37 PM
dhpro's Avatar
OK...I'll come back when I know more. BlownChevy, u have anything else to add? R/
Old Feb 6, 2006 | 01:43 PM
TurboGibbs's Avatar
Use the search button for info on pinning the crank. Try LS1TECH's search as well.
Old Feb 6, 2006 | 02:52 PM
BlownChevy's Avatar
blownerator
25 Year Member
Nope, check that crank pulley.
Old Feb 6, 2006 | 03:16 PM
MikeGyver's Avatar
How could the pulley slip on the crank that much? Wouldn't it weld itself to the crank in short order?
Old Feb 6, 2006 | 03:17 PM
BlownChevy's Avatar
blownerator
25 Year Member
no, but it will sure gaul it all to hell.
Old Feb 6, 2006 | 07:36 PM
onyx's Avatar
14 Second Truck Club
would
is your blower torqued correctly?
