blow off valve
Old Mar 29, 2008 | 03:41 PM
05chevy's Avatar
Default blow off valve
anyone have any idea on wut kinda aftermarket blow off valve would be good for my procharger d 1sc ? tryin to put 12 or so lbs of boost on my 404
Old Mar 29, 2008 | 10:52 PM
1Bad454's Avatar
Did you look at Prochargers blow off valves?
Old Mar 29, 2008 | 11:57 PM
AFI Performance's Avatar
You don't want a BOV, you want a Bypass valve. You can get by at that boost with the black anodized procharger one that comes in their newer kits, or get the Race bypass from procharger.
I like to use the Vortec Mondo bypass when higher amounts of air bypass is needed. You need to calculate the cfm your blower is making, and find a valve that can handle it. I have had cars that are a nightmare to tune only to be fixed with a proper sized bypass.
Superchargers make the same airflow being belt driven at any throttle position at any given RPM.
Old Mar 30, 2008 | 12:38 AM
jasond26's Avatar
I would go with the vortech mondo valve. That should be plenty for your needs.
Old Apr 1, 2008 | 09:40 AM
Can you explain on this, why bypass and not bov?
Is it because of being belt driven or the maf?
Old Apr 8, 2008 | 09:34 PM
Superado's Avatar
11 Second Truck Club
https://ls1tech.com/forums/showthread.php?t=701648
Old Apr 9, 2008 | 08:31 AM
Rick_Vor's Avatar
I'm running a Vortech Race Bypass and an eBay 3" cast adapter. At 320cfm flow rate, it will easily handle a D-1SC. If you buy a used one, just make sure it's the Bypass model, not the Blow-off version. They look the same but as Superado's link explained, a bypass is open all the time unless your under 4-5 inches of vacumn. The BOV is normally closed and just "burps" the excess boost when you suddenly close the throttle.
This is the adapter I'm running for the Vortech. http://cgi.ebay.com/ebaymotors/Type-...4294QQtcZphoto
It just replaces the stock ATI adapter pipe and lets you avoid buying a mounting flange and welding. I went to the local Auto Zone and found a pre-curved radiator hose that I used to go from the Bypass valve to the air filter elbow. Keeps everything out of view.
Rick
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
