Big HP guys come on in (700whp+)
Old Feb 8, 2018 | 06:03 AM
Choda's Avatar
How did you remove the plugs? Punch them out?
Old Feb 8, 2018 | 06:50 AM
MrHorsepowerLSx's Avatar
11 Second Club
There are a few aftermarket companies that make -AN fitting kits
Or you can source out an OEM 4 port vent system
Last option is to remove the rear plugs and drill them out to except -AN fittings and plumb up a vent kit your self
Old Feb 8, 2018 | 09:02 AM
03sierraslt's Avatar
Originally Posted by smokinlmm
I was told I couldn't run this??? Is that true? If I can I will add it when I do the new top end...
It won’t clear on a TVS without getting creative.
Attached Thumbnails Big HP guys come on in (700whp+)-397229b3-9d67-4f00-8c50-5a108ddabab2.jpeg
Old Feb 9, 2018 | 05:45 AM
smokinlmm's Avatar
I see that. Thank you!
Old Feb 9, 2018 | 10:55 AM
TXsilverado's Avatar
I think both.
I understand hottest. I would think those cylinders would be more rich than the fronts on a N/A application, lean on front inlet nitrous installs, and no different under boost.
Old Feb 9, 2018 | 10:46 PM
D1SCSS's Avatar
Im not sure what power my setup is running, however I'm running the front coolant bypass lines only. The rear are capped off with no over heating issues on my daily driven LSX432. I have thought about running all 4 in the future just as a precaution.
Old Feb 12, 2018 | 11:09 AM
Vortec350ss's Avatar
Its really only an issue with the factory intake... they have a very direct flow path from the TB. Look at the front holes and where the intake runners end in comaprison to the TB. the air needs to make a hard 90 right after the TB to make it to those holes
matticus
Apr 14, 2016 03:37 PM
jkwalkercchs
14
Mar 31, 2008 02:03 AM
02Vortech
Jan 22, 2007 07:23 AM
parish8
Oct 5, 2002 12:25 AM
parish8
Jun 12, 2002 04:27 PM
