Best wrap for turbo pipes.
Is this the stuff I need to be using?
Design Engineering DEI 010110 - DEI Exhaust Wrap Kits - Overview - SummitRacing.com
Yes that is the type of wrap to use. Don't buy the titanium DEI whatever you do. Also, I wouldn't buy that kit, those ties aren't worth a **** and unless you have an oven or kiln to fit your hot pipes in that rattle can coating isn't going to work the way its intended.
I used hose clamps at each end and cut the excess off with a dremel cutoff wheel. You can use wire also and just twist it with pliers. The rattle can is a sealer that is supposed to protect the wrap, but it has to be baked on to work correctly.
