Best cam for supercharger
Old Nov 20, 2013 | 06:12 PM
ElktonsDG's Avatar
Default Best cam for supercharger
What's the best supercharger cam for 1900 tvs, stage 3 208 heads, longtube set up? Let me kno what you guys think.
Old Nov 20, 2013 | 06:36 PM
Atomic's Avatar
I have a gauge for that
engine size?
Old Nov 20, 2013 | 06:52 PM
03sierraslt's Avatar
Truck size, what stall speed converter do you have or plan to run?
Old Nov 20, 2013 | 07:01 PM
ElktonsDG's Avatar
5.3 Rcsb 07 classic yank ss3600
Old Nov 20, 2013 | 07:03 PM
ElktonsDG's Avatar
I was looking that the Vinci triple x. What do u think
Old Nov 20, 2013 | 07:13 PM
That cam would work well, myself I prefer something with a bit more exhaust bias and a 113-114lsa. I like -1 to -8 overlap on TVS's, that Triple X is -5 so....That is allot of converter for a TVS as you are going to miss out on allot of the low end that it will create. Typically I would not suggest a cam that big in a 5.3 but with your stall speed it will be ok. How high do you plan to spin the motor?
FYI the Trucker cam is a proven performer, allot of guys have ran it with great results.
Old Nov 20, 2013 | 08:03 PM
ElktonsDG's Avatar
Thanks for the help. 6500 but that's a the track a few times a month, not too often.
Old Nov 20, 2013 | 08:18 PM
TX Tahoe Z71's Avatar
I am partial to the tried and true GT2-3. Has a mid and top end that always puts a smile on my face, but drives and idles like stock.
Old Nov 20, 2013 | 08:21 PM
ElktonsDG's Avatar
Thanks kinda want a choppy idle
Old Nov 20, 2013 | 08:25 PM
IMO that cam is a bit on the large size if that is your planned Peak RPM, you could drop the duration a bit lower and bring the power curve down so you can actually use more of it. Check out the trucker cam.
The GT2-3 is another popular cam, myself I am not a huge fan of it as the intake duration is really low and I prefer a bit more overlap to keep cyl. pressures in check. A GT2-3 will have a stockish to almost smoother then stock idle and should yield good fuel economy, however your 3600 converter is way overkill for it IMO.
