Belt alignment, help!!!
Old Jun 15, 2010 | 07:41 AM
blownss06's Avatar
Default Belt alignment, help!!!
I havr a pulley boys pulley and yesterday my belt broke. I put a spare one on and when looking at it the maggie pulley needs to come out. How do i do this? Also i will be upgrading the tensioner to the magnacharger one and to 100mm pulleys. As far as the 100mm pulleys i was thnking of reichard racing, but have read the i uave to shim those also. Anyways need advice on changing all of this out and aligning everything up. Pics and part# would help.
Old Jun 15, 2010 | 11:16 AM
dhpro's Avatar
I've been going thru all this. Call Joe @ Leftcoast32...he's the expert. I've always used Innovators pulleys. As for the blower pulley alignement, put some washers on the back to move it outboard, or change/shave all the others. Before spending all kinds of cash on 6 ribs, go to 8ribs instead if u plan to keep a small blower pulley and upgrade to O/D crank, it'll cut back on belt slip. U have any belt dust now? Is your tensioner @ 3oclock or 90* with belt on?
Old Jun 15, 2010 | 11:21 AM
Chavette's Avatar
Is your crankshaft pulley pinned and bolt still torqued to spec?
Old Jun 15, 2010 | 11:26 AM
Pooki's Avatar
As for shimming the maggie pulley, any alternator shop or = will have many size shims on hand for cheap. Just measure what size you need and they will have it or make one fast enough.
Old Jun 15, 2010 | 12:57 PM
dhpro's Avatar
washers are cheaper than shims...they'll prob tell u they used shims when all they did was add washers!
Old Jun 15, 2010 | 03:48 PM
blownss06's Avatar
Well i just ordered the HD tensioner from magnacharger ($115,pretty cheap). Tomorrow i will call left coast and order the 100mm pulleys. Yes my crack is pinned. You can see the belt is not aligned on one of the idlers and the alt. pulley was getting polished.
Old Jun 15, 2010 | 11:23 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm wondering if your pulley is on backwards, or has been installed incorrectly(pressed too far on, or not far enough...).
Any chance you could post a couple of pics?
Old Jun 16, 2010 | 06:11 AM
blownss06's Avatar
The pulley from pulley boys comes with a hex head to grab it with a wrench. So the is no way to put it backwards.
Old Jun 16, 2010 | 10:25 AM
DrX's Avatar
DrX
Make sure that the new pulley is the same offset as the original from MagnaCharger.
Old Jun 16, 2010 | 12:40 PM
I have seen it done before...
You have the "nut" facing the front of the truck, right?
