Atomic & Fast + SC?
Old Mar 7, 2013 | 08:53 AM
USAFzombie's Avatar
Default Atomic & Fast + SC?
So from what I've been reading, Atomic EFI and FAST EFI don't support superchargers. I called and talked with a tech from MSD, who said that the R&D had been put on hold for it.
I'm just curious what specifically causes it to not work with a SC. He mentioned a different sensor not having support, but it seems like if you can carb a SC, you should be able to support it with an EFI system that is better than a carb.
Any better explanation?
Old Mar 7, 2013 | 09:48 AM
dirt track racer 81's Avatar
Megasquirt. Look that up.
Old Mar 7, 2013 | 09:52 AM
Area47's Avatar
big stuff supports it.
Old Mar 7, 2013 | 09:53 AM
USAFzombie's Avatar
I saw one small bit of information on it, but the post said it was a very in depth install... and it was supposedly not as good as the Atomic. Thoughts on that?
Old Mar 7, 2013 | 10:19 AM
Are you still going to run the Weiand blower?
Old Mar 7, 2013 | 10:21 AM
USAFzombie's Avatar
I would LIKE to... but it's not like I already bought it. I was just curious the reasoning.
Old Mar 7, 2013 | 10:54 AM
Phantom's Avatar
11 Second Club
Megasquirt is the easiest wiring job I've ever done on my truck
Old Mar 7, 2013 | 10:57 AM
USAFzombie's Avatar
I glanced at their site.... it basically is a lot of reading and the purchase options from a couple of the vendors make no sense. I'm going to have to read more on it in a bit.
What kind of economy are you able to get out of switching to the EFI system?
Old Mar 7, 2013 | 11:06 AM
Phantom's Avatar
11 Second Club
I was getting 15-16mpg on e85.
When it was factory efi with 91octane it was no problem to get 20+mpg with 4.56 gears and 31" tall tires
Old Mar 7, 2013 | 11:43 AM
Gadgetized's Avatar
I'm not sure what your vehicle is, but the stock computer will handle about anything you can do to your vehicle. I actually bought a megasquirt because I heard so much good stuff about them. I have since bought EFILive. I will be switching my Chevelle over to a stock GM computer this year. If you still want to go with an aftermarket computer, I have a brand new Megasquirt that I will be selling. It is a very simple effective system.
