ATI damper crank pinning
Old Nov 14, 2020 | 06:38 PM
darkirish63's Avatar
Default ATI damper crank pinning
Just wondering if anyone has pinned a crank for an ATI Super Damper while motor is in the truck and how difficult it is. Thanks.
Old Nov 15, 2020 | 02:05 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I have, It's not that bad. Just take your time or you will snap the drill bit like I did.
It seemed like the bit wasn't cutting any more and I pulled it out to clean and inspect and then put it back in. I tried to put some more force on it and that's when I snapped the bit. I am not sure if the bit went dull or if I hit a hard spot in the crank snout.
Also I wanted to make sure the Pin was inline with the factory key way incase I needed to service the crank and pull the timing set gear.
Old Nov 15, 2020 | 02:13 PM
Yeah...I have a habit of breaking metal . Thanks for the heads up.
Old Nov 15, 2020 | 02:39 PM
1FastBrick's Avatar
No problem! There is an industrial Hardware store in the area that had a similar long drill bit and I was able to finish the job with only a slight delay. There bit seemed to cut better and I drilled almost all the way through the old sacrificial bolt.
MikeGyver
Jan 28, 2020 10:29 PM
blwn4.8
Jan 6, 2012 04:54 AM
robjen1019
Nov 1, 2005 09:10 PM
Hemi Killer
Jun 29, 2004 11:20 AM
