Arps ???
Old Feb 29, 2012 | 12:32 AM
  #21
No I only have 150-200 miles on it since I did the rod bolts. I figure if they haven't messed upbby now, the never will
Old Feb 29, 2012 | 12:33 AM
  #22
Originally Posted by Suburbazine
You've only put 150 miles on it. Talk about how reliable it is after you have 10,000 miles more.
I honestly don't think there would be a difference between 150 miles or 10k miles. If its right then its right and if its wrong it would've messed up by now
Old Feb 29, 2012 | 02:52 AM
  #23
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by james8997
I don't see why changing rod bolts would cause a failure in less they were over torqued. Or wasn't installed/torqued correctly.
This is again a roll the dice chance. The factory bolts are tq down. The engine/ bearings are worn to a set pattern, after driving. You pull a bolt loose it takes the load of the bearing. Nothing is giving that the main will set exactly the way it was as untouched stock. it could be in a few miles or 1000 miles, but it is a chance that it will or could spin. It's just the way it is. Again I have seen very few rod bolt failures, but i really don't know what I am talking about
Old Feb 29, 2012 | 06:59 AM
  #24
slow67's Avatar
Gingervitis Addict
X2. I think the whole "weak rod bolts" came from the 98-99 LS1 cars.
Another thing I hate is how people put a HP rating on rod bolts. Rod bolts don't hold HP, the keep the piston from smacking the head during the exhaust stroke. Heavier rods/pistons and RPMs are the killer of rod bolts.
Old Feb 29, 2012 | 12:11 PM
  #25
smokeshow's Avatar
Mod with training wheels
Doesn't stop companies from listing power ratings with ARP bolts lol... If anything it should be a rating involving RPM and rod/piston/pin mass.
SS94S10
Jan 3, 2019 01:57 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
Tuckin15s
Sep 23, 2015 09:35 PM
