Anything else needed for j-tube swap?
Old Jan 10, 2009 | 09:21 AM
chevrolade's Avatar
Default Anything else needed for j-tube swap?
I got a 90mm j-tube coming,wanted to see if theres anything else needed for the swap,besides a 90mmtb,i already ported mine,could i still run my tb?
Also how did you guys swap them out?still on vehicle?
Old Jan 10, 2009 | 02:24 PM
thunder550's Avatar
High on diesel fumes
You need some anaerobic sealant to go between the s/c housing and the j-tube.
Old Jan 10, 2009 | 06:10 PM
chevrolade's Avatar
Alrite cool,that it?so my stock tb will work?
Old Jan 10, 2009 | 06:48 PM
thunder550's Avatar
I'm not sure what the bolt patterns are on the two, so I don't know the answer to that question.
Old Jan 10, 2009 | 06:51 PM
vanillagorilla's Avatar
Why would you switch to a 90mm j-tube and not get a matching TB? I strongly recommend you upgrade the TB soon, otherwise the gains from the j-tube won't be seen.
Old Jan 10, 2009 | 07:35 PM
Breeze's Avatar
11 Second Truck Club
If youre 08 78mm T/b is the same as my 03 then it will not bolt up as the 78mm has 3 bolts and the 90mm has 4 bolts so the 78mm will not bolt up to the 90mm j-tube. I was able to swap out the my j-tube while the S/c was on the truck.
Old Jan 10, 2009 | 07:39 PM
chevrolade's Avatar
This is my TB,its a 4bolt and i ported the crap out of it.
Old Jan 10, 2009 | 07:41 PM
leftcoast32's Avatar
FormerVendor
That is the truck division 90mm throttle body and will bolt right up.
Old Jan 11, 2009 | 06:24 AM
Breeze's Avatar
I'm confused.
Old Jan 11, 2009 | 09:17 AM
FormerVendor
He ordered a 90mm J-Tube because we thought his TB was the old style 78mm. When he posted pictures of his TB I recognized it as the truck division 90mm. So his truck cam from the factory with a 90mm on his 4.8.
