Anyone using a 408 with a blower?
Old Nov 15, 2005 | 06:54 PM
  #21
parish8's Avatar
single digit dreamer
Originally Posted by Jamesbond2509
Those numbers pretty well jive with my latest setup. I have the 2.2L KB which is rated for 920 CFM @ 13000 rpm. Im overspinning it to about 15lbs @ 15000RPM on a 3inch pulley. The road dyno at 13lbs on Efilive shows consistently 500-520rwhp. It seems reasonably but I will need to go to dyno soon as I can get a new tranny. Once the intercooler is in, I plan to spin well into 18000rpm. The mustang guys do that all the time and get massive horsepower.
the rpms are the question here. they never take these charts out far enough . i suspect the whipple can goto 18,000 rpm like the radix and kb. if so that would seem to take the hp up a ton. someone needs to try it and see.
Old Nov 15, 2005 | 06:59 PM
  #22
Originally Posted by parish8
that blower should still be prety good at your level. i would suspect a tuning issue kept you from gaining more power. what were your a/f's? how much timing? i would first suspect very low timing.
if your set on keeping the whipple then yeah a 408 would probably be more than you need. a 370 might be a good deal for you. that would be your 6.0 block and crank but add some good rods and pistons. i see the heads as optional but heads are a controversial subject in the FI world. definately want to bump up the cam.
11.5ish afr, 16deg timing. I too thought I should have been much higher than 416rwhp. Christ, I ran 13.06@102mph a few weeks back in a 6100lb truck. I was thinking about a 370 actually. I'm told Combination has one they are trying to get rid of. I have also heard that the stock heads are just fine.
Old Nov 15, 2005 | 07:02 PM
  #23
parish8's Avatar
i missed the stock manifolds part. is your exhaust completely stock? not sure but that could be the problem. i would still expect more hp than you showed going from 11 to 15psi. did you log the boost? did it hold steady or did you just recored a peek number?
Old Nov 15, 2005 | 07:16 PM
  #24
stock manifolds(until next week), Dynatech cats, Flopro muffler. Stupidly, i wasn't watching the boost gauge when we dynod and the dyno doesn't/didn't record boost. I may have been slipping like hell and not even known it. I didn't have any belt dust though. I can hold 15lbs on the street/track. 2.75" blower pulley and 7.5" crank pulley on a 2 belt whipple.
I NEED more low end power. and I NEED to get to low 12's in the 1/4.
Old Nov 15, 2005 | 07:25 PM
  #25
Cam, headers and 4L80 Parasitic drag is the difference between us. I dont think the shorty headers contribute much. The cam made a huge difference in the upper RPM's My timing is at 15 WOT and 12lbs. You should very close. The Whipple is 0.1L bigger. Also you should hear belt slip.
Old Nov 15, 2005 | 09:23 PM
  #26
Slowhawk's Avatar
LS1Tech Sponsor
It's obvious the blower is the limiting factor of the setup.You could go 370ci and show more boost or go 408 and show less boost. Either way the 408 will destroy the 370ci. The 408 will peak HP/torque earlier in the curve giving a higher average power.
The obvious fact is that we have a 6.0 motor pushing 15lbs of boost and it only makes 400rwhp.The timing was maximized around KR,meaning there is an issue with the existing setup that needs to be addressed.I like the route of overbuilding what you need.That gives alittle satisfaction that it can be pushed harder if you need to.
Old Nov 15, 2005 | 09:53 PM
  #27
Thanks. This is exactly what I wanted to hear. I guess I should have asked, knowing the limitations of the whipple, which motor 370 or 408 would give me the most power, peak and overall. So now the problem is, who's 408 to buy? So many choices, so many different prices. I will never make 1000rwhp, we all know this based on the fact that I'm running a whipple. So, that being said, do i NEED to get the most expensive 408 that will support the most horsepower? If yes, so be it. I'm just trying to understand everything before I spend way more money than I have, lol.
Old Nov 15, 2005 | 10:20 PM
  #28
greentahoe's Avatar
Its all about the dollars in my opinion, 408 or 370 isnt realy a huge difference, I may go with a 370 and go through with a solid buildup with a T trim and use the left over for a sick hidden DP setup. Hell I may even see what a stock LQ4 will stand up to . I should be able to get tuning pretty close as I have an onboard wideband wired up.
Old Nov 15, 2005 | 10:29 PM
  #29
.T.'s Avatar
.T.
hmmm....
Old Nov 15, 2005 | 10:54 PM
  #30
Originally Posted by .T.
hmmm....
c'mon teddy, don't hold out on me.
and, ffhp has a smokin deal on a 408 longblock over on ls1tech. Anyone have any thoughts on it? feel free to PM me if you have negative things to say about it. Don't want anyone to get offended.
