Anyone use Comp turbos new oil less turbos?
Old Apr 5, 2011 | 06:05 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by quicksilverado
The reason they make more tq, is because everyone uses a smaller turbo on rear mounts. Then they turn up the boost and run out of turbo, which causes the tq to go so high. Same thing happens on a front mount, when you run out of turbo the tq will go way up.
Care to explain that a bit more? Horsepower is a calculated with torque and RPM.
(Torque x RPM) / 5,252 = Horsepower
In theory, increasing torque also increases horsepower which would result in a faster vehicle.
Old Apr 5, 2011 | 07:04 PM
kbracing96's Avatar
He is right, you get more torque cuz you run more boost in the lower RPM but then you run out of turbo to support the airflow at the higher RPM so the torque drops off up there as well as HP since like you said, HP is nothing more then torque x RPM and there is not enough turbo to support the airflow to motor in the higher RPM to make the HP.
Cool turbo's none the less!
Old Apr 5, 2011 | 09:07 PM
silver-mod-o's Avatar
Hunt&Fisherator
Would be sweet on a mid-mount setup.. Or even front mounted for that matter...
Old Apr 6, 2011 | 10:54 AM
slow67's Avatar
Gingervitis Addict
Other cool part is the turbo doesn't have to be mounted level.....
Choda
Jan 22, 2026 02:03 PM
chopperloco
Jul 10, 2016 10:45 PM
Silveradorst07
Dec 31, 2015 12:04 AM
Gadgetized
Jul 22, 2015 11:55 AM
