Anyone know how high the oil level is past the sensor?
Old May 13, 2013 | 10:44 PM
kelsey_canard's Avatar
Default Anyone know how high the oil level is past the sensor?
Going to weld a bung into my oil pan for my turbo drain. I had planned to weld it in right above the oil level sensor, but the starter limits how high up the pan I can go. I've got it about one inch above the oil level sensor now. Anyone know if this should be enough? If not I can move it to the front of the pan by the crank pulley. I can snap some pics tommorow if needed. Motor is a 2000 lq4 btw.
Old May 13, 2013 | 11:29 PM
Ferocity02's Avatar
That's high enough, right where mine is.
Old May 13, 2013 | 11:31 PM
Thats good news You wouldn't happen to have a pic of your's would you?
Old May 14, 2013 | 12:31 AM
Ferocity02's Avatar
No I don't, but it's straight above the oil level sensor about as high as I could get it. Oil does not come out of it with the oil to the full mark on the dipstick.
Old May 14, 2013 | 08:38 AM
nonnieselman's Avatar
I welded a bung behind the AC Compressor for mine.. Turbo drains straight down.
Old May 14, 2013 | 02:59 PM
tim wellington's Avatar
Default drain plug
are you guys removing oil pan or doing it on truck?
Old May 14, 2013 | 03:00 PM
I removed mine, but a bunch of guys do it on the truck.
Old May 14, 2013 | 09:13 PM
Here's some pics
Anyone else see an issue with this?
Old May 14, 2013 | 09:39 PM
GMCtrk's Avatar
Perfect position.
Old May 14, 2013 | 09:44 PM
Should this be high enough above the oil level? It looks to be a little lower than where people mount them on the front of the pan
