Any A/W Intercooled KBRacing setups?
Old Nov 21, 2009 | 03:36 PM
Coban's Avatar
Default Any A/W Intercooled KBRacing setups?
I'm thinking about trying it. I'd like to see if anyone else has any routing ideas.
Old Nov 21, 2009 | 03:55 PM
charcold-bowtie's Avatar
I would look at nelson's stuff for ideas. FarmTruc
Old Nov 21, 2009 | 03:56 PM
GMCtrk's Avatar
what's the advantage to A/W?
Old Nov 21, 2009 | 04:10 PM
SincalT/A's Avatar
The ability to obtain 100 percent efficiency.
Less piping.
Old Nov 21, 2009 | 07:56 PM
Coban's Avatar
Shorter piping. I would imagine that would have better response. Plus I don't really like the current A/A pipe routing. It does not agree with 05+ efans, espcially if you are still using the MAF sensor like me. I can't blame the kit though, as it was built for a 4x4 and 2 bar. I think the sway bar is in a diff location too.
Lower pressure drop through A/W intercooler from what I've been reading.
I did, but his turbo is in a very different location further away from the engine. His is one of the things that inspired me to look into it. I would like to eliminate that U bend before the TB though.
Old Nov 21, 2009 | 09:00 PM
LsxCody's Avatar
an a/w costs alot more doesnt it
Old Nov 21, 2009 | 09:21 PM
Coban's Avatar
Nope.
Old Nov 21, 2009 | 11:34 PM
FarmTruc's Avatar
Performance Trucks Sponsor
a/w isn't that much more. you'll be able to use a much smaller intercooler as well, so you have more options for location.
you will need a good heat exchanger however, a good pump, hoses and filler cap.
I only made the aluminum tubing like that for the maf, it'll have a short tube for non maf
thanks,
Old Nov 22, 2009 | 12:18 AM
LsxCody's Avatar
how much would a aw setup from you cost
Old Nov 22, 2009 | 11:44 AM
Coban's Avatar
Could you PM him, please?
Back on track. I think I found something pretty close to what I need. I think I could clock the compressor housing and it would discharge directly into the A/W core. I could relocate the BOV after. Hopefully he doesn't mind me using his good idea.
