Any A/W Intercooled KBRacing setups?
I'm thinking about trying it. I'd like to see if anyone else has any routing ideas.
I would look at nelson's stuff for ideas. FarmTruc
what's the advantage to A/W?
The ability to obtain 100 percent efficiency.
Less piping. |
Originally Posted by GMCtrk
(Post 4336829)
Lower pressure drop through A/W intercooler from what I've been reading.
Originally Posted by charcold-bowtie
(Post 4336828)
an a/w costs alot more doesnt it
Nope.
a/w isn't that much more. you'll be able to use a much smaller intercooler as well, so you have more options for location.
you will need a good heat exchanger however, a good pump, hoses and filler cap. I only made the aluminum tubing like that for the maf, it'll have a short tube for non maf thanks, |
how much would a aw setup from you cost
Originally Posted by LsxCody
(Post 4337066)
Back on track. I think I found something pretty close to what I need. I think I could clock the compressor housing and it would discharge directly into the A/W core. I could relocate the BOV after. Hopefully he doesn't mind me using his good idea.
(Post 4049583)
