Any one have the Silverado On3perfomance instruction CD
Old Oct 4, 2017 | 08:19 PM
Daniel-lsx's Avatar
Default Any one have the Silverado On3perfomance instruction CD
Any body have a copy of the instructions Cd for the Silverado kit, I can buy a copy.. thanks.
Old Oct 5, 2017 | 11:22 AM
Daniel-lsx's Avatar
Anybody? I message on3perfomace but no answer yet
Old Oct 5, 2017 | 12:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Not sure specifically what your looking for but there are lots of pictures on there Build thread on LS1 tech.
https://ls1tech.com/forums/forced-in...on-system.html
Old Oct 5, 2017 | 04:07 PM
Atomic's Avatar
I have a gauge for that
Yea, take the turbo kit:
and put it here:
All done
Old Oct 5, 2017 | 05:32 PM
MikeGyver's Avatar
That sounds like the voice of experience.
Old Oct 5, 2017 | 06:52 PM
RySmDPT14's Avatar
You don't need an instruction CD, its all straight forward. I got a kit dirt cheap and I will tell you, if i had the chance I would get a trick, or new era performance kit. With the on3 kit, I had to cut and radius the bends of the downpipe as it ran right out the fender/ into frame rail, the cross over pipe required extensions to fit my lift (not their fault), I had to make new intercooler pipes as well as the ones provided don't fit well, the turbo manifold makes in near impossible to change out plugs, you have to make your own spark plug wires (MSD kit works great), take apart the BOV and wastegate (stock 7 psi spring) to ensure good operation, my BOV was stuck, make sure you get the right MAP sensor, I needed a Zr1 and not the one they claim is required. BTW this was on a 2012 2500HD. I cant get accurate numbers as it doesn't fit the tuners dyno. also, use DEI titanium wrap on everything, I made heat shields from my old factory heat sheild as well as 1/4" aluminum for ac line safety. I can touch mu ac lines and they are warm not hot. I also recommend getting insulated heat sheilding from DEI to put on coolant reservoir and ac stuff.
Old Oct 7, 2017 | 10:00 AM
Boost-freak's Avatar
that's sums it up
Old Oct 8, 2017 | 12:57 PM
madmann26's Avatar
He's partial. Lol
