Another turbo build .... :)
Old Aug 11, 2016 | 07:35 PM
fctry286's Avatar
Originally Posted by Jonblarc7
So did you get to the dyno
I did. Went to the dyno this morning, having issue with convertor unlocking and building boost. Got to 12lbs and made 523rwhp. Ran out of wastegate spring to turn the boost up more.
This was on California pump 91 @15deg timing. 0 kr
Another run only hitting 10lbs.
I have some video as well.
Old Aug 11, 2016 | 08:07 PM
Superman09's Avatar
Truck Sponsor
Post up some videos, we would love to see them!
Old Aug 25, 2016 | 07:35 AM
Jonblarc7's Avatar
So do you still like the turbo over the pro charger.
Old Aug 25, 2016 | 07:48 AM
03sierraslt's Avatar
Not sure if that graph is right for your AFR but if it is then add some fuel through midrange and your tq will go up noticeably.
Old Aug 30, 2016 | 02:39 AM
fctry286's Avatar
I ended up adding some fuel. hopefully Friday we will see what she does at 16lbs, then add some E85 and let her eat.
Old Oct 12, 2016 | 03:33 PM
fctry286's Avatar
Update.
Turned the boost up to 16lbs and ran a 4th gear pull. truck made 544rwhp and 545trq. ran out of fuel pump at around 5,000 rpm's. this was on cali pump 91 as well. Need to get an electronic boost controller and ill set boost to 14lbs across the board.
jik294
Oct 21, 2016 12:44 PM
TBSS0930
Aug 4, 2016 10:46 PM
snogoer
Aug 3, 2016 02:38 PM
spudz
Jul 25, 2016 07:42 AM
nitrousaddict
Jul 21, 2016 06:00 PM
