another problem with my silverado turbo!!!
Old 08-13-2008, 07:50 PM
corvette_uae1's Avatar
Default another problem with my silverado turbo!!!
ok guys now about my truck as u said before it is so lean
so i did install holly 255 fuel pump in tank
and i did buyed ( fast 42lbs ) injectors part # 304208
but the problem is it doesnt fit my engine !!!! i've got the 2007 silverado 5.3 !!!
why the hell it doesnt sit !! i thought it will fit right on my engine i dont want to order and wait 3 weeks and the only injectors i found in dubai's shops is these . so what is the solution ????
i've seen this fuel rail in the same shop this is an ex.
http://www.compperformancegroupstore...ory_Code=FLRLS
if i did some work in this fuel rail would ill be able to fit the injectors???
Old 08-14-2008, 12:32 AM
kbracing96's Avatar
You can probable use those injectors with your stock fuel rails, but you will have to space up the rails 5/8" (15mm) and use longer bolts. You will also have to change the pig tails in the injector plugs as they are probable different too.
Old 08-14-2008, 01:31 AM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
You will need to get the installation kit for GM Trucks Nelson Performance sells them and is also a sponsor on the forum.
http://www.nelsonperformance.com/products.htm#fuel
Old 08-14-2008, 02:52 AM
TURBHOE's Avatar
why didn't you buy the marine injectors that plug right in?
Old 08-14-2008, 07:10 AM
zippy's Avatar
Can you post a picture of your stock injectors? You may have the flex fuel injectors and they do make very big direct replacements for them.
Old 08-14-2008, 11:18 AM
kbracing96's Avatar
Cuz he's in another country, he bought what the local speed shop had. Ever try to buy/ship stuff internationally, it's a PITA,
Old 08-14-2008, 05:08 PM
TURBHOE's Avatar
oh, gotcha.
Old 08-15-2008, 06:33 AM
hahahaha guys will its easier for u in u.s cuz u usually can get all the stuff u need in days
but for me i will wait 2 - 3 weeks and yeah sometimes while ur sitting waiting for ur order and counting hours and minutes when u got ur delivery they sent u wrong item like before i did order an stroker kit for my ford when i checked it it was ford focus stroker kit !!!!!
well thanks guys for the infos u really helped me alot .
peace
Old 08-15-2008, 06:37 AM
i did return the injectors
but i want to order the marine injectors to fit it without any headache!!
ok kb racing and 4.8 t guys i found these injectors
http://www.injector.com/fuelinjectors.php
this is what u mean right???
Old 08-15-2008, 07:19 AM
Low_LSX's Avatar
This is what you need.
http://cgi.ebay.com/ebaymotors/Delph...spagenameZWD1V
Quick Reply: another problem with my silverado turbo!!!
