another problem with my silverado turbo!!!
ok guys now about my truck as u said before it is so lean
so i did install holly 255 fuel pump in tank and i did buyed ( fast 42lbs ) injectors part # 304208 but the problem is it doesnt fit my engine !!!! i've got the 2007 silverado 5.3 !!! why the hell it doesnt sit !! i thought it will fit right on my engine i dont want to order and wait 3 weeks and the only injectors i found in dubai's shops is these . so what is the solution ???? i've seen this fuel rail in the same shop this is an ex. http://www.compperformancegroupstore...ory_Code=FLRLS if i did some work in this fuel rail would ill be able to fit the injectors??? |
You can probable use those injectors with your stock fuel rails, but you will have to space up the rails 5/8" (15mm) and use longer bolts. You will also have to change the pig tails in the injector plugs as they are probable different too.
You will need to get the installation kit for GM Trucks Nelson Performance sells them and is also a sponsor on the forum.
http://www.nelsonperformance.com/products.htm#fuel |
why didn't you buy the marine injectors that plug right in?
Can you post a picture of your stock injectors? You may have the flex fuel injectors and they do make very big direct replacements for them.
Originally Posted by 4.8T
(Post 3980128)
Originally Posted by kbracing96
(Post 3980264)
Cuz he's in another country, he bought what the local speed shop had. ;) Ever try to buy/ship stuff internationally, it's a PITA, :lol:
(Post 3980264)
but for me i will wait 2 - 3 weeks and yeah sometimes while ur sitting waiting for ur order and counting hours and minutes when u got ur delivery :bang: they sent u wrong item like before i did order an stroker kit for my ford when i checked it it was ford focus stroker kit !!!!! well thanks guys for the infos u really helped me alot . peace |
i did return the injectors
but i want to order the marine injectors to fit it without any headache!! ok kb racing and 4.8 t guys i found these injectors http://www.injector.com/fuelinjectors.php this is what u mean right??? |
This is what you need.
http://cgi.ebay.com/ebaymotors/Delph...spagenameZWD1V |
