another problem with my silverado turbo!!!
ok guys now about my truck as u said before it is so lean
so i did install holly 255 fuel pump in tank
and i did buyed ( fast 42lbs ) injectors part # 304208
but the problem is it doesnt fit my engine !!!! i've got the 2007 silverado 5.3 !!!
why the hell it doesnt sit !! i thought it will fit right on my engine i dont want to order and wait 3 weeks and the only injectors i found in dubai's shops is these . so what is the solution ????
i've seen this fuel rail in the same shop this is an ex.
http://www.compperformancegroupstore...ory_Code=FLRLS
if i did some work in this fuel rail would ill be able to fit the injectors???
You can probable use those injectors with your stock fuel rails, but you will have to space up the rails 5/8" (15mm) and use longer bolts. You will also have to change the pig tails in the injector plugs as they are probable different too.
You will need to get the installation kit for GM Trucks Nelson Performance sells them and is also a sponsor on the forum.
http://www.nelsonperformance.com/products.htm#fuel
but for me i will wait 2 - 3 weeks and yeah sometimes while ur sitting waiting for ur order and counting hours and minutes when u got ur delivery
they sent u wrong item like before i did order an stroker kit for my ford when i checked it it was ford focus stroker kit !!!!!well thanks guys for the infos u really helped me alot .
peace
i did return the injectors
but i want to order the marine injectors to fit it without any headache!!
ok kb racing and 4.8 t guys i found these injectors
http://www.injector.com/fuelinjectors.php
this is what u mean right???
Ever try to buy/ship stuff internationally, it's a PITA,
