Another catch can question... slight oil smell at idle
#31
Nope, I just wanted to make sure the turbo was nice and happy since the bearings look a little hot when I had it apart. Never ever had a smoking issue either, just to prove the point that if you have smoking issues the solution is not to use a restrictor or a smaller feed line.
#32
#33
The bearing clearances inside the turbo determine the flow rate, not the size of the feed line. BB turbos need restrictors because those seals dont handle the pressure as well (as they dont need to like JB units). Most of the turbos we use are oil cooled, so they need a lot of volume to keep from overheating.
Most of the time a restrictor band-aids a smoking turbo, but you are basically starving the turbo of oil. The solution is to upgrade/fix the drain situation.
#34
Drain is effected by hose size, angle, length, material, oil drain location.
And crank case venting.
#35
Well guys, I experimented a bit with breather filters, etc before the dyno and the truck definitely did not like that (strong oil smell). Not sure why, but the oil smell is lightest when PCV is actually "positive" and not just breathing/ venting. Passenger side to turbo inlet, driver's side through catch can and check valve to intake manifold.
I rerouted my turbo drain and haven't smelled any oil since. Even though PCV of any sort is not ideal technically, I am not getting much blowby, and I'm running a conservative tune. My catch can only has a small amount of oil after 5000 miles, so I'm going to leave PCV hooked up since I think my oil smell was probably the turbo drain...
#37
Originally Posted by TrickTurbo
How'd you re-route the drain line?
New location?
New location?
B&M Racing
Apr 12, 2016 12:06 PM
Lthompson
11
Mar 22, 2016 10:30 AM
