Another Blue Smoking Problem
Old Jun 1, 2015 | 11:12 AM
  #21
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Preshr
Right now I have the stock PCV set up but both of the valve covers are ran to a tee and vented under the hood. Which should make the PCV have no effect. Right?
I installed the turbo a couple weeks ago and started happening within a couple of days.
I will check shaft play later.
Thanks
How is pcv connect and both covers are vented?
If pcv is intact. And there are breathers.
You need a check valve in pcv line.
Other wise you are pressuring the crank case though pcv line.
And your rings aren't working properly under boost.
Old Jun 1, 2015 | 01:08 PM
  #22
Preshr's Avatar
Maybe I am making some a assumptions that are wrong. The line that runs from the top of the manifold back toward the back of the valve cover I cut and vented. Is this wrong?
Old Jun 1, 2015 | 01:13 PM
  #23
TrickTurbo's Avatar
Truck Sponsor
That sounds like your pcv line
So if you cut it you have 2 sides.
Engine
valve cover.
Take a look and see how and where you have hoses routed.
Got any pics?
Old Jun 1, 2015 | 01:39 PM
  #24
Preshr's Avatar
Engine
valve cover.
Got any pics?
I can take a picture later.
I cut that line, ran a hose around under the throttle body, connected a tee with that line and the passenger valve cover vent line, off of that tee I ran a line over to where the air box used to be. I ran it there so I can run a catch can and vent back to pre turbo vacuum.
I apologize if this is simply a stupid error on my part but thank you for helping.
Old Jun 1, 2015 | 02:44 PM
  #25
TrickTurbo's Avatar
Truck Sponsor
ok
So the hose from top of the intake.
You cut it.
You have 2 ends now. One side goes to the intake the other side goes to valve cover.
did you cap/plug the intake side and run valve cover side under the throttle body. T'd into the front passenger side valve cover. Then to air box?
Old Jun 1, 2015 | 02:59 PM
  #26
Preshr's Avatar
ok
You cut it.
Right. I capped the intake there. I also capped the port on the throttle body where the passenger valve cover vent ran to.
Old Jun 1, 2015 | 03:56 PM
  #27
TrickTurbo's Avatar
Truck Sponsor
Ok. So pcv is not functioning.
Depending on size of how. You probably are not venting enough.
Old Jun 1, 2015 | 06:46 PM
  #28
Preshr's Avatar
The turbo shaft feels really good. No play what so ever.
What is a good size for vent lines?
I believe mine are 1/4 ID.
Old Jun 1, 2015 | 06:51 PM
  #29
SloSVO's Avatar
if your not venting enough of the crankcase pressure, the pressure will pressurize the turbo drain and the oil wont drain... I'd clean out the turbine housing and take the oil cap off the fill neck.. wrap a rag around the fill neck and ziptie/ rubber band it and go drive it.. i have "fixed" many bad turbos this way...lol
Old Jun 1, 2015 | 07:16 PM
  #30
TrickTurbo's Avatar
Truck Sponsor
1/4 way to small.
