Am I safe
Old Nov 14, 2012 | 04:03 PM
turbo-ls7's Avatar
Registered User
Default Am I safe
Ok so today in driving and my oil light comes oil shut engine off now seems like I'm not getting enuff oil pressure what could it be motor not making any weird sounds steal drives good it's in between the frist line like it has Like not even 16 pounds of pressure
Old Nov 14, 2012 | 04:05 PM
tiffo60's Avatar
Could be sending unit going out, but for the chance that its the pump I wouldn't take the chance and keep driving it
Old Nov 14, 2012 | 04:11 PM
turbo-ls7's Avatar
Registered User
Would that be the oil pressure sensor because it made a code pop up and it was the sensor but I made sure it was plugged in good is it hard to change the oil pump its like 100 bucks for a new ls3 pump
Old Nov 14, 2012 | 04:40 PM
M&M Turbochargers's Avatar
prob better get it figured out before you drive it anymore
Old Nov 14, 2012 | 05:51 PM
turbo-ls7's Avatar
Registered User
Just changed the oil sensor and still the same so ima change the oil tomarrow and see it theirs any metal shavings in it hope not
Old Nov 14, 2012 | 06:30 PM
tiffo60's Avatar
gauge clusters can take a crap too
Old Nov 15, 2012 | 06:02 AM
joeyc125's Avatar
11 Second Truck Club
You can buy a cheap mechanical gauge from oreillys for about $15. That would tell you if it's a true reading, or just an electrical error.
Old Nov 15, 2012 | 10:37 AM
Johnmaster's Avatar
MASS seller approved
This is exactly what happened to me on my 04. Gauge needle servos are notorious for crapping out, guys have made entire businesses out of rebuilding these dashes, check fleabay and you will see hundreds offering to rebuild them a fee.
Old Nov 15, 2012 | 10:43 AM
turbo-ls7's Avatar
Registered User
It's a 2011 truck man I just don't seem like its the gauge but ima go to oralleys tonigh don't I plug it in where the oil filter goes
Old Nov 15, 2012 | 10:48 AM
custom 68's Avatar
Well since you didnt tell us anything about this. Your title is Turbo... does this have a turbo or is it stock? If it is a 2011 is should be under warranty unless you have done the turbo mod?
Mine is a 2004 and my gages are all over the place it is electrical issue.
