Am I safe
Ok so today in driving and my oil light comes oil shut engine off now seems like I'm not getting enuff oil pressure what could it be motor not making any weird sounds steal drives good it's in between the frist line like it has Like not even 16 pounds of pressure
Would that be the oil pressure sensor because it made a code pop up and it was the sensor but I made sure it was plugged in good is it hard to change the oil pump its like 100 bucks for a new ls3 pump
Well since you didnt tell us anything about this. Your title is Turbo... does this have a turbo or is it stock? If it is a 2011 is should be under warranty unless you have done the turbo mod?
Mine is a 2004 and my gages are all over the place it is electrical issue.
