All Go No Show: budget bed-mount turbo build thread
Old Dec 15, 2015 | 08:28 PM
  #21
ZO6Ted's Avatar
Ceramic bearing turbo with no oil supply needed? Spendy though.
Old Dec 16, 2015 | 08:18 AM
  #22
TrickTurbo's Avatar
Truck Sponsor
Yep comp turbos.
Used them before they work well.
Goes against the budget build.
Old Dec 16, 2015 | 09:35 PM
  #23
Cam Zurg's Avatar
Registered User
I am fixing to buy my wastegates. I want to run two ebay wastegates (in case one fails). Does anybody know which off brand ones have interchangeable springs and diaphragms with the name brand ones?
Old Dec 17, 2015 | 11:49 AM
  #24
Look up Zombie on LS1tech. He had a lot of success and research into remote mount turbos.
I would personally skip the self contained turbo oil system. Too much hassle. Good scavenge reservoir, pump, and lines will be all you really need.
Old Dec 17, 2015 | 02:31 PM
  #25
TrickTurbo's Avatar
Truck Sponsor
don't want it to fail. Don't by cheap.
The gate is the control for your kit. This part is the one thing I would never use eBay for.
If your gonna but 2 then by a good one. Just a thought.
Old Dec 17, 2015 | 02:42 PM
  #26
Cam Zurg's Avatar
Registered User
I can buy two ebay wastegates for $50 dollars each, or one name brand for $400 dollars. Many people have used ebay wastegates with great success. A name brand wastegate can still fail as well.
The biggest "fear" of using ebay parts is their potential for failure. If I have two then that completely fixes the problem. If one fails under boost the other will take over.
On top of that, I would prefer to spend $300 dollars elsewhere.
Old Dec 17, 2015 | 02:43 PM
  #27
Cam Zurg's Avatar
Registered User
Thanks for the advice ill check him out
Old Dec 17, 2015 | 02:55 PM
  #28
TrickTurbo's Avatar
Truck Sponsor
Never said a good gate couldn't fail.
just given a warning.
Good luck on your build.
Old Dec 17, 2015 | 02:57 PM
  #29
Cam Zurg's Avatar
Registered User
Thank you. I do appreciate your constructive criticism.
Old Dec 17, 2015 | 05:49 PM
  #30
anheuserbusch08's Avatar
this thread is gonna go to ****. rear mount is never a budget build. good luck. youre better off buying a used turbo kit than doing what you are trying to accomplish.
