All Go No Show: budget bed-mount turbo build thread
Old Dec 15, 2015 | 11:16 AM
Cam Zurg's Avatar
Registered User
Here's some photos
Attached Thumbnails All Go No Show: budget bed-mount turbo build thread-image.jpg
Old Dec 15, 2015 | 11:27 AM
Cam Zurg's Avatar
Registered User
Another one
Old Dec 15, 2015 | 11:41 AM
kbracing96's Avatar
There is TON's of STS type info in the archives of this forum. That was the first type turbo setup I had on my truck before I built my first front mount.
You will still need a return oil pump though, as gravity drain wont be enough even from bed height when you are acceleration and it will backup and push past the turbo seals.
Wrapping the pipes from the manifolds to the turbo in a rear mount situation is a MUST for helping spool, night and day kinda difference. I messed with this for 2 years back in the day.
Old Dec 15, 2015 | 12:18 PM
JordanH's Avatar
Restricted
Originally Posted by Cam Zurg
Hello everyone. I have been lurking for years and am finally ready to start my car project. The platform is a 2002 silverado rcsb 5.3 l59 base model 2wd 85k miles. The plan is to keep it daily drivable with an end goal of 600rwhp. The first step will be turboing the stock 5.3 to whatever the stock 4l60e (400hp?) can handle. Then after building a 4l80e and upgrading the rear end, crank up the hp. This will be done in my garage with the help of a few friends.
The plan is to bed mount turbo an ebay gt45
The mindset behind a bed mount turbo for me is this:
-Cost savings by using stock configured exhaust
-Retention of all factory parts under hood
-No melted plug wires, etc.
-All the benefits of an STS style turbo setup but with the turbo protected from the elements
-Turbo upgrades in the future will require no hot side modifications.
-And last of all I think it will be unique.
-I am not too worried about lag because I will be running an auto and can load the torque converter
I am fixing to order a Stigan gt45 from amazon. Anyone used this brand gt45 before?
Not sure how much that turbo from Amazon is, but this seems like a smokin hot deal!!! VS Racing
Old Dec 15, 2015 | 12:37 PM
Cam Zurg's Avatar
Registered User
I payed $250 for mine from a company called stigan on amazon. They seem to make a lot of factory replacement turbos and all the reviews were pretty good on them. Ill let you know how it looks when I get it.
A turbo mounted in the bed, would be at the same height as a turbo mounted under the hood. There for I think it would drain comparably to a front mount turbo, No? I greatly appreciate the critical thinking and advice.
Never the less, If I need one, I'll get one when the time comes.
Old Dec 15, 2015 | 12:42 PM
kbracing96's Avatar
Might be close to the same height, and might drain ok when sitting still or slowing down, but when you are accelerating, it won't drain well at all. Has to fight that force and the resistance of the hose, and I'll bet it will be a loosing battle, lol.
Old Dec 15, 2015 | 06:51 PM
Cam Zurg's Avatar
Registered User
Alright that all makes pretty good sense. But just for the sake of argument, wouldn't a front mount turbo have oil drain issues on deceleration then?
Old Dec 15, 2015 | 07:47 PM
TrickTurbo's Avatar
Truck Sponsor
Nope. The front mount drain hose is around 18" long going straight down.
Bed mount. Same height but your hose now is gonna be 6-8 feet long.
And is not going straight down. It's in an ugly angle.
Old Dec 15, 2015 | 08:10 PM
Cam Zurg's Avatar
Registered User
Thanks for your input trick turbo. looks like Ill be in the market for an oil pump then. I guess that also means there is no reason not to run a stand alone oil system for the turbo.
Old Dec 15, 2015 | 08:16 PM
TrickTurbo's Avatar
Truck Sponsor
Self contained.
Would need an oil pump that pushes 20-40psi.
Oil tank with fill neck and venting
Oil cooler. Cooler needs to in air flow or have a fan blowing on it.
All that keeps adding to to ticket.
