Alkycontrol/2 bar install question
Old May 19, 2007 | 08:17 PM
Stoichiometric's Avatar
Default Alkycontrol/2 bar install question
I am installing an Alkycontrol kit that came with a 2 bar map sensor and got hung up at the point where the map sensor only connects to the PAC box. I would like to use a 2 bar custom OS in EFI live, so I need to connect the 2 bar map to the engine control wires (stock map wires) as well as the PAC box. The pictures show what I am looking at, do I need to splice into the stock map sensor wires? Or, do I need an additional map sensor that plugs in the stock location? The truck has a Magnacharger, fwiw.
Old May 19, 2007 | 08:43 PM
KySilverado's Avatar
I run the same parts. Don't hack up your wiring. Just put a 2 bar map on the engine. GM part number 12580698 and keep that map sensor for the alky kit.
Old May 19, 2007 | 08:52 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Bingo. Julio will tell you the same thing, but because he was as much granularity to the PAC as he can get.
Old May 19, 2007 | 09:46 PM
Cool, that is what I was hoping to hear. Less splicing is better . Thank you for the part number, I'll get one on order. Thank you for the quick info.
Old May 20, 2007 | 01:01 AM
2004SSS's Avatar
this is where im at too. i may use this map possibly as my pcm map because this will hook up to a hose easier stockck style would. also because im not running my truck intake anymore.
Old May 20, 2007 | 09:59 AM
The stock style map will plug into hose if need be. My dad used a piece of 1/2" (I think) hose to move the stock map on his C5 because of firewall clearance issues with a Fast 90.
Old May 20, 2007 | 10:10 AM
I AM A MOTHERF*CKER
Yeah, just take off the rubber grommet on the stock style map -- hose barb underneath.
Old May 20, 2007 | 10:18 AM
I have one other question about the Alkycontrol kit, where did you guys find switched 12v under the dash to power the PAC? The pump has a large motor, so I need to find a wire fused for at least 15 amps.
edit. My truck is an 05, so it uses data bus. I am still searching for answers, LOL.
Old May 20, 2007 | 08:38 PM
Well, I fixed up the wiring I already had, added a relay and everything runs great right now. I am using the only switched 12v pin I could find on the driver side fuse pannel to trigger the relay, the only problem might be that it becomes 5v when the key is in acc. position. I had some heater circuit codes pop up a while ago, I though that may be due to using that pin. I am up and running now though
Alkycontrol is great! The kit works flawless. I pulled some fuel out of the PE table to get an 11.5:1 AFR. I also bumped my timing from 17 degrees to 25. Before Alky, I would get a bit of knock at 17 degrees, now I don't have a hint and am running 25. The truck pulls much harder now. I can't wait to get it back to the track. Thanks TurboBerserker and KySilverado for the help.
Old May 20, 2007 | 08:41 PM
I pulled in a big hot wire from under the hood and put it to a relay then ran a switched source from the fuse box to pull in the relay and power the pump.
EDIT: oops just read that is what you did. Great minds think alike.
