air fuel ratio on sts
The only AFR guage worth fooling with is a wideband,you'll need to add a bung into your exhaust pipe to mount the wideband o2 sensor near your front narrowband o2 sensor.I prefer mounting the guage on a pillar mounted pod.Or you can unscrew a stock o2 sensor if you don't plan on perminently mount the wideband o2.
Originally Posted by ogkevin13
its juat a a/f gauge not wideband and its electrical just 3 wires power ground and another wire that am tryin to fine out where it goes?
How do I change this text
what wire do i hook up my air fuel ratio gauge to get a good reading on my 2001 silverado 5.3 with the sts set up?
How are you tunning this??
I also agree with ktmrider, buy a wide band.
true am saving up for a wideband now just my friend gave me this one and i have the pod with an empthy spot so i just wanted to mount it on and hook it up. does n e one know what wire i need to tap into and where so i can get the light show?
GXPJAY
Feb 13, 2022 08:15 AM
Corvette454l88
Sep 1, 2016 01:24 AM
ZO6Ted
Aug 12, 2015 07:50 PM
