air fuel ratio on sts
Old May 29, 2006 | 07:20 PM
ogkevin13's Avatar
Banned
Default air fuel ratio on sts
what wire do i hook up my air fuel ratio gauge to get a good reading on my 2001 silverado 5.3 with the sts set up?
Old May 29, 2006 | 07:25 PM
TG02Z71's Avatar
Did your gauge come with some type of sensor and or a bung to weld into your exhaust for mounting it? Post up what you have.
Is it just an AF gauge or a wideband?
Old May 29, 2006 | 07:35 PM
The only AFR guage worth fooling with is a wideband,you'll need to add a bung into your exhaust pipe to mount the wideband o2 sensor near your front narrowband o2 sensor.I prefer mounting the guage on a pillar mounted pod.Or you can unscrew a stock o2 sensor if you don't plan on perminently mount the wideband o2.
Old May 29, 2006 | 07:43 PM
ogkevin13's Avatar
Banned
its juat a a/f gauge not wideband and its electrical just 3 wires power ground and another wire that am tryin to fine out where it goes?
Old May 30, 2006 | 04:17 PM
ktmrider's Avatar
To be honest, I would not waste your time with that non-wideband model. It taps off your existing narrow band O2's and will not read accurately outside of the 14-15 range. Save a few bucks and buy a wideband, your engine will thank you for it!
Old May 30, 2006 | 04:25 PM
Wilde Racing's Avatar
How do I change this text
How are you tunning this??
I also agree with ktmrider, buy a wide band.
Old Jun 1, 2006 | 01:02 AM
ogkevin13's Avatar
Banned
true am saving up for a wideband now just my friend gave me this one and i have the pod with an empthy spot so i just wanted to mount it on and hook it up. does n e one know what wire i need to tap into and where so i can get the light show?
GXPJAY
Feb 13, 2022 08:15 AM
Corvette454l88
Sep 1, 2016 01:24 AM
wrb002
Aug 31, 2015 12:00 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
