Aeromotive 340 wiring.
Old Feb 5, 2012 | 05:18 PM
Pocket's Avatar
14ga is ample but uncommon. Anything larger than 12ga is a waste of money
Old Sep 2, 2012 | 05:01 PM
iregret's Avatar
Charlie Murphy!
Originally Posted by sprayedenali
just run a 10ga or so wire from the battery to a relay and use the stock power wire for the pump to switch the relay. very simple!
If its that simple, why is a hot wire kit 77.00?
Racetronix - Pump Wiring Kit MP150/280, Walbro CK* - Kit Configuration Page
Old Sep 2, 2012 | 06:04 PM
Ferocity02's Avatar
The racetronix kit takes the guess work out of it. And it comes with everything you need and nice features, fuse, BAP connection, correct connectors, upgraded fuel pump connector, etc. If you did it yourself you would spend nearly the same amount.
Old Sep 2, 2012 | 07:11 PM
TRD_Tundra's Avatar
I got the racetronix hot wire kit and and a center inlet aeromotive 340 too. I'll be installing this sometime next week. On a STOCK returnless fuel system. Hopefully I dont have issues like stated.
Old Sep 4, 2012 | 03:08 PM
Dropped&Hopped's Avatar
so far the aermotive 340 has been good to me on my truck. its returnless.
fuel pressure is a constand 60-62lbs at idle when running.
Old Oct 2, 2012 | 09:13 AM
nicky g's Avatar
Did u do the wiring also or just install it the way it is
SS94S10
Jan 3, 2019 01:57 PM
murderedSS
27
Oct 12, 2015 11:13 AM
12secSS
Sep 16, 2015 03:59 PM
chevstang421
Sep 10, 2015 09:16 AM
slowswb
Sep 5, 2015 02:27 PM
