aem af guage
Old Jan 28, 2010 | 07:33 PM
Most Hated's Avatar
Default aem af guage
what wrong we u go wot and the af gauge read just lil lines but works well under normal driving its and aem gaug
Old Jan 28, 2010 | 07:48 PM
03sierraslt's Avatar
What #'s is it showing before it shows ---? That means its out of range, either way to rich or way to lean. If it was lean enough to go out of range I doubt it would still be running. I believe the range on the AEM guage is 10.0-1 to 18.0-1
Old Jan 28, 2010 | 08:07 PM
quicksilverado's Avatar
Mine only goes down to 11-1. If that is the case with his, it could be in the 10-1 range.
Old Jan 28, 2010 | 08:41 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Marco, replace the sensor. That will take care of it. I'll dig up the part number for you.
Quoted from AEM's website. The part number for a replacement UEGO sensor is 30-2001. They are all over ebay.
Old Jan 28, 2010 | 08:51 PM
He could be to rich. Mine goes --- if I have the meth is turned up to much.
Old Jan 28, 2010 | 11:03 PM
LsxCody's Avatar
mine will show those lines if it gets too lean,but if its too rich it will just read 10.0,wont show any lines then,10 is as low as itll read
Old Jan 29, 2010 | 01:24 AM
Blown06's Avatar
8 Second Truck Club
Mine will read down to 10. Get new sensor like other stated. Usually fixes any problems with them. I've already had to replace a sensor on mine and I had about 1000 miles on it when it went out.
Old Jan 29, 2010 | 03:09 AM
Most Hated's Avatar
it happened to my friends gauge that wat i thought too bad sensor
Old Jan 29, 2010 | 03:10 AM
Most Hated's Avatar
thanx
Old Jan 29, 2010 | 03:12 AM
Most Hated's Avatar
naw dont think hess too rich he was at 11.0 with 10 psi now he has 12psi
