advantage on more boost or timing
Old Apr 12, 2007 | 09:15 PM
whoopassracer's Avatar
i want to go that route again, but do u think im pushing it at 13psi on a 5.3, i also have the dual meth nozzles with an extra one,(3rd nozzle) so my iats shouldnt go to high,
Old Apr 12, 2007 | 09:37 PM
SCIV's Avatar
Of course you are. Any boost is more than the stock motor was designed for. The higher you go, the quicker it'll blow.
Old Apr 12, 2007 | 09:52 PM
Crash Dummy's Avatar
Former Moderator :(
Timing below 15 degrees makes your EGTs go off the scale and promote detonation, You can cover it up with a real rich mixture but what you have to understand is that the fuel quality is one of the most biggest factors. In a perfect world everyone would run C16 race gas 20 degrees of timing and a ton of boost. I would set the timing around 15-16 degrees and run as much boost as your fuel will allow and call it good. High EGTs on a LS2 will butt the top ring gap and pop the top of the piston off, with no signs of detonation at all. If you plan on running timing below 15 deg you had better put a EGT gauge in and try to keep it under 1600 degrees. Pistons and cats melt in the 1700 degree area.
Old Apr 12, 2007 | 09:58 PM
parish8's Avatar
single digit dreamer
that sounds reasonable to me. i have always ran my timing around 15deg(on pump) and maximized boost.
Old Apr 12, 2007 | 10:20 PM
thats sounds like an idear, so if i can set the timing at 15*'s and then i could probably get around 10-11psi, would this be good
Old Apr 12, 2007 | 10:22 PM
and this would be done with the 2.75pulley not the 3.1
thunder550
Oct 8, 2015 04:53 PM
fastjweb
Aug 15, 2015 10:47 AM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Gadgetized
Jul 18, 2015 02:15 PM
