Actual BSFC
Old Oct 22, 2012 | 01:07 PM
  #21
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by Atomic
Yea, which sounds about right...
by a few points I mean 0.01-0.05 lambda. So If I tune it for 0.8 lambda on gas only itll be around .76-.78 with meth.
Scared me for a minute. Even so, that's up to about .75 of an AFR you could get back -- think where you could spend .75 AFR
Old Oct 22, 2012 | 01:16 PM
  #22
Atomic's Avatar
I have a gauge for that
Haha, well I was at 105% IDC on my 6.39 run last week. When I finish my cam swap im going to try 70psi base pressure which will make them 139.5lb/hr to see if that helps.
Old Oct 22, 2012 | 01:21 PM
  #23
I AM A MOTHERF*CKER
So that's 1367 bhp (using the .78 BSFC which isn't correct at that IDC, right?). How much boost?
Retuning for your meth would help a bit too.
Old Oct 22, 2012 | 01:26 PM
  #24
Atomic's Avatar
It ranged from 99-105 if you want to get picky, lambda from .78 to .8 with meth on top. Around 20psi
I found the .78 while not using meth, so im actually using more fuel than the IDC alone would tell you.
Old Oct 22, 2012 | 01:28 PM
  #25
I AM A MOTHERF*CKER
Yeah, but you are also using more IDC now so the BSFC would be higher than .78 too, yeah?
SloSVO
Nov 22, 2020 07:34 PM
Gadgetized
Oct 22, 2015 09:06 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
vmaxpro
Sep 28, 2015 11:10 AM
