Actual BSFC
#21
#22
Haha, well I was at 105% IDC on my 6.39 run last week. When I finish my cam swap im going to try 70psi base pressure which will make them 139.5lb/hr to see if that helps.
#23
Retuning for your meth would help a bit too.
#24
It ranged from 99-105 if you want to get picky, lambda from .78 to .8 with meth on top. Around 20psi
I found the .78 while not using meth, so im actually using more fuel than the IDC alone would tell you.
#25
Yeah, but you are also using more IDC now so the BSFC would be higher than .78 too, yeah?
