90mm UMI TB Conversion Complete - Pics inside
Old Feb 21, 2007 | 11:11 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by trever1t
I called it!!
Hey, your not running a 2-bar tune yet?
No 2 bar tune here... Yet
The MAF is maxed out my 5800rpm. I am going to do a true 4" cold air intake system, remove the MAF, and have a 2 bar tune done. Then go from there.
Old Feb 22, 2007 | 07:19 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Hmm, the intake sounds interesting.
Old Feb 22, 2007 | 11:32 AM
04Denali's Avatar
Jason,
I'm glad it worked out for you.
Can't wait to see her run.
Mark
Old Feb 25, 2007 | 03:03 PM
BLASTER's Avatar
Looks good. What blots and gasket did you use to mount it up?
Still looking for those to complete my conversion. Thanks
Old Mar 25, 2007 | 02:12 PM
GoatChs's Avatar
Late on board here.
Jason, was it "necessary" to eliminate the EGR, or did you do that for performance or ease of install? Can the EGR be retained? Did you use the UMI TB as preference...can other 90mm TBs be used instead (already have a Nick Williams on the GTO and will be changing to a Holley for hood clearance reasons)?
Old Mar 25, 2007 | 05:26 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by GoatChs
Late on board here.
I eliminated the EGR because the j-tube did not have provisions for it. In order the for the EGR to be retained, the throttle body flange would need to hava a hole for it to screw into.
However, you can do what some have done and just modify the current j-tube opening out to 90mm and retain the EGR. You will also have to redrill the flange to accept a 4 bolt throttle body and use a j bolt.
Here is how Justin did it;
https://www.performancetrucks.net/fo...0mm+conversion
And BigTex;
https://www.performancetrucks.net/fo...d.php?t=358691
Any 90mm throttle body can be used. I used the UMI because I heard it was the best one for the cale operated throttle bodies.
Good luck man.
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
subeone
Aug 19, 2015 07:44 AM
chacho44
Aug 17, 2015 03:36 AM
BennyB
Aug 1, 2015 08:48 AM
