90mm UMI TB Conversion Complete - Pics inside
Old Feb 14, 2007 | 08:10 PM
Last Call's Avatar
TOTM: January 2007
Default 90mm UMI TB Conversion Complete - Pics inside
Just finished up the j-tube and umi throttle body install. Had to get a 4" coupling to mount the throttle body to the radix air tube, deleted my egr and blocked off the port on the header with a plate. I also had to have the throttle cable plate redrilled to and moved over slightly to make sure the cable were working at good angles.
I havent went WOT yet because I still need to get tuned. It does seem to have low throttle issues which I think (hope) can be tuned out. Runs more rough in when cold as well.
Im going to get tuned next week and hopefully report back a solid gain. I do have 100% throttle movement because it is not DBW. I am also going to have the meth turned up and hopefully a few more degrees of timing. I have 21 degrees now, so I think with more meth and this mod I should be able to see 25 degrees of timing.
I am hoping for 25rwhp which would put me right at the 500rwhp mark. I will be sure to report back with a new dyno graph next week.
Old Feb 14, 2007 | 08:21 PM
laynlow77's Avatar
awsome!
Old Feb 14, 2007 | 08:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
You suck!
J/K, happy for ya, I bet you make more than 25 out of it. Too bad you cant meet up with us for a run on Saturday
Old Feb 15, 2007 | 08:46 AM
CHarris's Avatar
Have you retuned your iac table? I'll bet you have a slightly different size iac passage. You might have to tweak your throttle stop as well.
Looks great!
Old Feb 15, 2007 | 02:09 PM
Breeze's Avatar
11 Second Truck Club
Damn you're sure hard to keep up with no doubt you should hit 11s this year lookin good Jason.
Old Feb 15, 2007 | 02:21 PM
Last Call's Avatar
TOTM: January 2007
Thanks guys... I will get it tuned next week.
Hopefully i dont t max out the MAF.
Old Feb 21, 2007 | 10:35 PM
Last Call's Avatar
TOTM: January 2007
90mm tb conversion proved to be worthwhile. Gain was 30rwhp and 23rwtq with tuning.
Old Feb 21, 2007 | 10:38 PM
BlownChevy's Avatar
blownerator
25 Year Member
Its nice to see the gains that were questioned back in the day are actually coming to life now. I remember when there were members questioning the 30-40 rwhp gains from this mod.......well na sayers, here is your proof....
trever1t's Avatar
Originally Posted by trever1t
You suck!
I called it!!
Hey, your not running a 2-bar tune yet?
Old Feb 21, 2007 | 10:42 PM
Keith's Avatar
With almost a pound less boost too!
