90mm throttle body?
Old Jan 8, 2010 | 01:46 PM
  #31
DrX's Avatar
DrX
Originally Posted by CAPO
hi guys ,
i installed the tb today , and started the engine , normal idle , but when i apply the padel , th rpms goes at 2000 and stay no matter what it will not come down if i apply again , it will go to 3000 and stay
and idea how to fix this
Have any DTCs been set?
Old Jan 8, 2010 | 01:49 PM
  #32
CAPO's Avatar
No at all
i heard from friend that idle learning will take 2 hours o learn new TB or just tune it
Old Jan 8, 2010 | 06:34 PM
  #33
DrX's Avatar
DrX
No at all
If adjusting the tune I would only change the ETC Throttle Area Conversion/Scalar to .0158.
Idle Learn Procedure
Automatic Transmission
Perform the following procedure in order to return the learned idle to the correct position:
1] Turn OFF the ignition.
2] Restore the PCM battery feed (if disconnected).
3] Turn OFF the A/C controls.
4] Set the parking brake, and block the drive wheels.
5] Start the engine.
6] Ensure that the engine coolant temperature is more than 80°C (176°F).
7] Shift the transmission into Drive.
8] Allow the engine to idle for 5 minutes.
9] Shift the transmission into Park.
10] Allow the engine to idle for 5 minutes.
11] Turn OFF the engine for 30 seconds.
Old Jan 9, 2010 | 02:25 PM
  #34
CAPO's Avatar
did you mean this , i had to write the recent numer here ???
Old Jan 9, 2010 | 03:13 PM
  #35
truckmann's Avatar
That is the right place, but that is not the right number to use for a NNBS. It is correct for my truck. I believe you that number needs to be about 4725, but Dr.X can probably tell you for sure. I don't believe changing that number is going to make much if any of a noticeable difference for you application though.
Old Jan 9, 2010 | 08:07 PM
  #36
DrX's Avatar
DrX
I would try the 4725 if your calibration uses area rather than a factor. This may not make much difference, but it will be more accurate. This is the number used on the LS2/LS7 cars. Odd that the 8191 number is already the same as in the calibrations for those cars.
Old Jan 10, 2010 | 02:31 AM
  #37
CAPO's Avatar
it didnt work either the 4725.2500 and the learning thing , plz another help
Old Jan 10, 2010 | 10:02 AM
  #38
DrX's Avatar
DrX
Does the throttle blade move through its full range if you step on the pedal? Does it open 100%?
Old Jan 10, 2010 | 11:31 AM
  #39
CAPO's Avatar
i have to check , and i will do
Old Jan 10, 2010 | 11:56 PM
  #40
CAPO's Avatar
in the log its shows 83 % only
