90mm throttle body?
Old Dec 22, 2009 | 01:49 PM
CAPO's Avatar
good news , with boost should be more , do you think guys the torque will jump little bit ??
Old Dec 22, 2009 | 02:03 PM
Mangled03gmc's Avatar
Baltimore Whore
Normally when you get a increase in air, you will get hp-tq increases...
Old Dec 22, 2009 | 02:09 PM
CAPO's Avatar
my torque is lower than HP its 430,s , i wish to have more torque than HP ,
Old Dec 22, 2009 | 02:18 PM
SILVERADO11's Avatar
Originally Posted by BlownChevy
10-15 HP is a pretty standard gain. The biggest advantage is the loss of restriction before the blower. any time you can take away the restriction the more efficient the blower is going to be.
Would that help lower IAT at all? my IAT's kill me in the summer here in AZ Thanks for the info!
Old Dec 22, 2009 | 08:21 PM
DrX's Avatar
DrX
You need a diesel...... or set your rev limiter to 5200RPM. jk
Torque will increase if you can cram more air into the cylinders, but HP will also increase because it is a mutiple of torque.
HP = (TQ x RPM)/5252
Old Dec 22, 2009 | 08:29 PM
DrX's Avatar
DrX
That is the theory. Based on physics it should decrease the Delta T of a draw-through supercharger.
Old Dec 22, 2009 | 11:53 PM
CAPO's Avatar
if you have high IAT go with methanol , in summers my IAT is 55 C , with methanol its dorped to 27 that,s ahalf of it , my timing is 21 at summers pulling 455 hp
use M3 race fuel , no water
Old Jan 2, 2010 | 11:31 AM
CAPO's Avatar
Default stock TB size
what is our stock size of 5.3L ( LH6 ) ??
is it 75 , 78 or 87 mm , ?? i found new one for 200 $ and just wana know LH6 vs LS7
thanks
Old Jan 2, 2010 | 12:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
what year truck is it from?
Old Jan 2, 2010 | 01:29 PM
My stock throttle body on my 5.3 is a 78mm i think its the 3 bolt style.
