90mm TB Install
Old Sep 26, 2006 | 07:21 PM
  #21
2004SSS's Avatar
so has anyone got the 90mm to work properly for the fly by wire? i remember reading that they werent opening completely at wot?
Old Sep 26, 2006 | 07:50 PM
  #22
KySilverado's Avatar
Originally Posted by Wilde Racing
One job of that coolant line is to help get air locks out of the cooling system. I don't think you should block it.
Planning on running a hose and from the head outlet to the radiator. It would look cleaner capped off but don't want any cooling flow problems. Air lock release makes sense.
Old Sep 26, 2006 | 07:53 PM
  #23
BlownChevy's Avatar
blownerator
25 Year Member
that is what you will need to do. you CANNOT cap it off.
Old Sep 26, 2006 | 07:54 PM
  #24
They work on certian applications. 02 trucks from what I've read. Think the consensus is even not going complete 90* they should flow better than the 78 mm full open.
A picture of the 2 side by side speaks volumes.
Old Sep 26, 2006 | 09:42 PM
  #25
2004SSS's Avatar
yeah im sure it still out flows the 78 but for the cost of that mod i would want it work right, im sure you would benefit from it opening 100%.
Old Oct 3, 2006 | 12:04 PM
  #26
Well still waiting on the gasket maker. Shipped from CA. Did get out and hook up the TAC module and TB. Good news it works as expected.
Old Oct 6, 2006 | 11:53 AM
  #27
It is on. I was about to pull the darn blower knowing I would not be able to get one of the bolts out of the J-tube. Bottom passenger side, turns out there wasn't a bolt in it? Started, idled and couple trips up and down the road says its working fine.
After a bite to eat gonna swap the 16" wheels on and head to the track tonight. Only mod being the new TB since last time to the track. 50-60 degree low humidity weather. Hoping to pull a new best. Wish me luck!
Old Oct 6, 2006 | 12:10 PM
  #28
ZR1 DREAMING's Avatar
Good luck man, hope to see good results!
Old Oct 6, 2006 | 12:47 PM
  #29
360demonRT's Avatar
wish i had my truck back, but it'll be a while. i'd come down to mtn park and visit if i had it. that's a big damn single. just a question, call me stupid, but why do chevy's use a singe port TB? mine is a twin 53... how does that flow in comparison to your single 90? i heard somewhere that a single was better for taller RPM's but i dont know.
Old Oct 6, 2006 | 12:48 PM
  #30
360demonRT's Avatar
oh and there is a car quest in mt. sterling lol. not to far from the track. when i get my truck back i may come up to LEX and hang out, do you hang out at the parkette with them?
