90mm J-Tube Conversion
Old Dec 19, 2007 | 09:26 PM
xsports33's Avatar
Default 90mm J-Tube Conversion
Are the benefits of the conversion from the 78mm to the 90mm J-tube and throttle body only seen at high RPM's? Unless you're at WOT you won't be maximizing it's full potential, right? I've heard of better throttle response and lower IATs, but the HP/TQ gain is going to be at the top end correct? What about bottom end loss, or is there no bottom end loss just top end gain?
My truck rarely sees high RPMs and WOT so i'm trying to justify the cost of this upgrade versus gains. I like the sound of better throttle response and lower IATs to help with towing.
Old Dec 19, 2007 | 10:12 PM
BlownChevy's Avatar
blownerator
25 Year Member
Hey man, hows it goin?
Use the LS2 TB and the conversion harness from torquerush.com. Joe has the 90mm J-tubes in stock check with him for your parts!
Old Dec 19, 2007 | 10:26 PM
xsports33's Avatar
Hey Brian!! Thanks for your help on the phone earlier today, didn't expect you to answer the phone. I plan on getting the larger heat exchanger and 90mm J-Tube from Joe, the DrX harness, and probably the LS2 TB from eBay or something. Now i just gotta find the sealer and the O-ring
Old Dec 19, 2007 | 10:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
Joe has the o-ring, and I have it on good advisement that WCCH has a TB left with your name on it.
Old Dec 19, 2007 | 11:51 PM
Last Call's Avatar
TOTM: January 2007
Here is a dyno graph of before/after the 90mm conversion. No other changes besides tuning.
I gained both torque and horsepower accross the board:
Old Dec 20, 2007 | 08:32 AM
leftcoast32's Avatar
FormerVendor
The Loctite 550 or 510 is what to get as a sealer. I can have everything else waiting for you like we talked about. GM carries the o-rings in stock just ask for one for any of the LS2 vehicles like the SSR, TrailBlazer SS, Corvette, GTO or CTSV. I think I have an o-ring in stock, I will have to check.
natejk
Nov 15, 2016 08:05 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
Chevy305
Sep 28, 2015 09:21 PM
spooneralmighty
Sep 11, 2015 02:28 PM
