82% duty cycle with 60s
Old Sep 14, 2008 | 02:43 AM
7845's Avatar
Banned
Default 82% duty cycle with 60s
tonight i did a WOT run in 3rd and noticed my duty cycle at 82%. i have motron 60s with 58psi with 0 vaccum. this was at 15psi of boost. fuel system is dual 255s -8 feed -6 return. does thsi sound reasonable? also is there any reference to HP that is being made with this much duty cycle on properly setup fuel system?
Old Sep 14, 2008 | 10:41 AM
kbracing96's Avatar
What AFR and how many RPM? My 346 with 60lbs/hr 11.0 AFR and 170kPa and 6000rpm are at 66%
Yours seems a little on the high side, but Im guessing your still a bit rich and you turned the screws to the little 4.8, lol
Old Sep 14, 2008 | 10:58 AM
03sierraslt's Avatar
Easy killer, dont pop that thing right away. What AFR and RPM like KB mentioned.
Old Sep 14, 2008 | 11:08 AM
dirt track racer 81's Avatar
interesting, I wouldnt have thought youd be that high on such a little motor..
Old Sep 14, 2008 | 11:22 AM
Highest I have seen mine is 78% @ 5700rpm. somewhere around 11psi
Old Sep 14, 2008 | 11:24 AM
kbracing96's Avatar
I ran mine all the way up to 98% when I was running E85 on the 4.8, lol
Old Sep 14, 2008 | 11:45 AM
mine are at 110% any how.. have you put a guage on and actually checked the fuel pressure at that rpm? dont really seem right
Old Sep 14, 2008 | 11:51 AM
kbracing96's Avatar
You have 60's at 110% on Gas???????
I was out of fuel pump. added fuel to try to richen it up, went for 92% to 98% IDC but no change in AFR. You got to remember with E85, I was shooting for 7.3 AFR, could only get 8.1
Old Sep 14, 2008 | 11:54 AM
60s haha yea NA on gas. no i have just stock ls1 injectors at 65psi. it used be be 95% on my 6.0 now with my 370 its a bit higher. how ever i am actual thinking about converting to e85 though
Old Sep 14, 2008 | 12:02 PM
kbracing96's Avatar
Haha, I didn't think so, that's like 750-800 hp area
