82% duty cycle with 60s
like i said on ss.
i get my 60's to about 95% idc when only running boost at 15 psi and also using a bit of meth. id say your close i dont have a big motor only a 370 so with a 4.8 id guess thats a about right, my fuel pressure is 58 psi boost referenced. so at 15 psi boost the pumps are actually making 73-75 psi
for ppl with HPTuners heres a log of how fast that needle snaps
i found out my map scale was off in the engine dianolis [sp] so thats why all my historgrams and logging is off
WOW, that scan just hurts my head. You are at 15+ AFR for 5.5 seconds after going WOT. Then it just rockets to 7500RPM (5 seconds later though) and 170KPA and then AFR is still an after thought. Can you post your config file you are using? along with a scan where you are confident the histograms are playing nicely? I am with kb, seems high but...7500RPM is no joke though.
trust me im leary about the tune. thats why i want to get it safe as soon as possible. i bene chasing bugs, for 2 days i had 6 cylinders. 2 coils were dead, then i find out the map scale is off but in that run i hit 15psi which is what 210 kpa? my scanner was readign right
