8 rib kit
Old Sep 30, 2013 | 07:45 PM
05 vortec high output's Avatar
Default 8 rib kit
What size of belt are y'all guys running with a TVS 1900 with a 2.80 pulley for the 8 rib set up??
Also what size of belt y'all running for the a/c. Thanks.
Old Sep 30, 2013 | 07:56 PM
03sierraslt's Avatar
Do you have a Standard or OD crank pulley?
Old Sep 30, 2013 | 08:05 PM
I'm going with a 10% overdrive pulley.
Old Sep 30, 2013 | 08:11 PM
While I can't really help you considering I dont have a 2.8 pulley, you can get a 6 rib belt that fits and just convert the # to 8 rib. I am sure someone will chime in what that setup.
Old Sep 30, 2013 | 08:20 PM
TIM Z's Avatar
11 sec. Truck Mod
Also what size idlers are you running ? I know one is adjustable .
You can wrap a string around the pullies and mark it to find out what size belt you need . Or do what I've done before and go to the parts store and try a couple sizes
Old Oct 1, 2013 | 09:51 AM
Vortec350ss's Avatar
I didnt even think of that... good idea Tim! haha
Old Oct 1, 2013 | 09:56 AM
Just don't forget to account for belt stretch and tensioner position.
Old Oct 1, 2013 | 09:00 PM
TIM Z's Avatar
11 sec. Truck Mod
Pat and I went thru this last year when we did the 8 rib conversion.
Yep like said make sure the tensioner is riding where it needs to in the middle or close to as possible . Hard throttle on / off snaps like to eat belts if the tensioner isn't set correctly .
Old Oct 3, 2013 | 09:30 PM
Ok. Will try that. Thanks for the good help.
Old Oct 3, 2013 | 09:31 PM
Got the metco 100 mm idler pulleys
