8.1l whippled WONT START rebuilt motor
Old May 31, 2012 | 12:27 PM
whippled 8.1l build's Avatar
Default 8.1l whippled WONT START rebuilt motor
ok so i have just finished rebuilding my motor and now i cant get it to start. had a low voltage code (ground wire) fixed that now i cant get it to start at all.
Old May 31, 2012 | 04:14 PM
i have now checked 2 dif cylinders and i am not getting over 100lbs of compression in the engine. also found a nice little fact that the fireing order for a 01 is different from a 02 but summit says that the cam works from 01-07?
Old May 31, 2012 | 05:59 PM
ugh multiple companys multiple answers.. comp cams says its the valve springs need to be changed from stock to COMP Cams 911-16.. machine shop said i shouldnt have presoaked the lifters in oil. summit says they will refund my money if i return the cam.. wtf i just want a answer as to why i halfto back off the retaining nuts on my rockers to get any compression above 0.. raylar roller rockers and his special locknuts
Old May 31, 2012 | 06:09 PM
Wide Open's Avatar
I have no idea why you wouldn't pre-soak your lifters in oil.
Pushrods too long holding the valves open maybe?
Old May 31, 2012 | 08:00 PM
new lifters, stock pushrods with 250k on them from original motor. only things we are thinking now is that it needs a relearn for the crank sensor, and the camshaft may have been ground wrong.. i have a merc cam im thinking of putting in
Old May 31, 2012 | 10:49 PM
Wide Open's Avatar
Let us know what you figure out.
Old Jun 1, 2012 | 01:21 PM
well i have several cylinders with GOOD compression 160+ and some that wont go above 30-60 so what we can conclude is that the valves arnt seating properly. valve grinding compound was used to get a seal and aparently it didnt do good enough so 175 at the machine shop and ill see if that takes care of it
Old Jun 1, 2012 | 01:37 PM
Wide Open's Avatar
Bummer!
Old Jun 1, 2012 | 02:14 PM
yea your telling me
Old Jun 2, 2012 | 06:05 AM
xx_ED_xx's Avatar
Do what? what cam shaft did you put in it? me personally i would chuck those stock push rods in the trash. I forgot the details of your motor what did you do to it.
You can email me direct
edward.coss@gmail.com
