70mm Z71 Stage III Build
#21
Parts are piling up.
Im getting pretty excited. Everything I have taken apart looks great. Cam, pistons, bearings, heads... everything. Saturday will be a block cleaning day and maybe even filing the rings, scrub the pistons and put the short block back together. No hurry no worry.
is 600 wheel a realistic goal? 93 pump with a basic rebuild and triple 12?
#22
#24
Truck Sponsor
#26
#28
Motor was torn down and looked great. All the bearings looked ok, the block cleaned up well, I used simple green and a wire brush. Gadgetized checked/filed the rings and "trued" the decks with a neat trick. The hone was a little scary at first but it worked great once I broke it in and got the throttle under control.
Ill scrub the pistons down, order up my new main, rod and cam bearings then start slapping this baby together. All my parts, except the cam, have showed up. Heads should be done next week.
The board is set, pieces are moving.
